hi just upgraded my n82 to the latest software which come with online share 3, when instaled it places two icons on my home screen i cant get rid of. i have no activated the ovi, flickr application etc. so just need help to get rid of the icons. no settings on my standby screen help.
cheers wayne
On Line Share Icons!!!!
You can't remove them.
Did you install Share Online 3 ? or did you get it as part of the firmware update?.
If you installed it the only way to get rid of it is to do a backup then a *#7370# format, finally restore your backup.
(When I upgraded mine to the latest firmware I didn't get SO3 so I assume you have installed it)
