Nokia N70 Music Edition
I open gallery In Nokia N70 Music Edition and select and view my pictures then press options and press Zoom In (or hotkey button 5) it shows a message saying
"Gallery:
Feature not supported"
it works before but now..
Zoom In Feature works fine in Options --> Edit.
please help me.
pls u restart the phone..
nizam_up wrote:pls u restart the phone..
I restarted many times and even i also used soft and hard reset but no avail
You most likely have a program which was manipulated (cracked) by someone like BNPDA, which makes changes within the system. sometimes these get downloaded and installed without us knowing they were even cracked. i.e. from some freeware sites. Look at the last few programs you installed before you tried the gallery and uninstall it. As a last resort, restore from your memory card. Hope this helps.:icon14:
Remove coreplayer, that's your issue. If you still want to use it you need a modified version for the n70, do a google for it.
Thanks alot brother, it really worked
