hi, have r66 with maps for uk, spain and france, my question is, if i were to travel from somewhere in spain, to say, somewhere in france, can i do a search for the french destination in r66, and will i find it if i have the spanish map selected, or would i have to load the france map, and then how would i navigte through spain?? or do i need a 'europe' map?
thanks!
Gavin Watson wrote:hi, have r66 with maps for uk, spain and france, my question is, if i were to travel from somewhere in spain, to say, somewhere in france, can i do a search for the french destination in r66, and will i find it if i have the spanish map selected, or would i have to load the france map, and then how would i navigte through spain?? or do i need a 'europe' map?thanks!
You need to manually select the map you are interested in using for a search or for Navigation. Your current location (UK/France/Spain) does not matter.
You could install a 'Main Roads of Europe' map, but as the title suggests, these maps are not as detailed as individual country maps.
hi... ok, want to go from cadiz (spain) to calais (france)... have spain and france map but isnt working...
if i try loading spain map and entering calais it says destination outside map, if I select France map and try, it says GPS position off map. How can I do the trip? Do I need the Europe road maps?
