i want a master key of security code
nokia 3230
Master Code! Keep Dreaming! it is impossible 2 configure Master code,i think you have to go at nokia center to know the master key,You key mastercode into your mobile when it prompt you for security code. It will not change when you change your security code. You can use over and over again if you forgot your security code.
If you wanna Master Code There's A nice Software Called MCode
Can Retreive your Code And So you can use it To change your Lock Code the software need to know your Serial Number, Which you can get by Entring
*#06#
Or
See it (you will find it under the battary) , ....
Or
you can Reformating your Phone By Turn Off your Phone Then Press And Hold
Green Key(Dial) And "3" And "*" Then Press and hold Power Switch
Even It Say Formmating And see Long Bar Full Screen Wait you will See Nokia Logo Then The Phone Will Erase It's Code to Be "12345" Try it
i have this problem Before And Do Above ...Just Try
Regards
marwaen wrote:If you wanna Master Code There's A nice Software Called MCode
*#06#
Or
Or
Regards
thanks for nice post bro
