Startup nokia "hands" graphic
3 replies · 2,836 views · Started 04 February 2003
Anyone know where this animated hands graphic file is kept on the Z drive? Had a look for *.gif but couldn't find anything.
Perhaps it is an MBM file?
Check this topic
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=6495&highlight=bootup
Read through all the posts on the 5 pages but never came across anything saying what the file is called.
Found a file called startup.mbm in Z:\Apps\Startup - is that it?
Tried viewing it with XnView but says there is only 1 colour and it is all black. Never saw any hands 😞
Ok, i gone help you a litle bit
Page 4:
GhostDog
Correction,the mbm is animated when aniviewer is used.
Too bad we dont have a clue in what way =>Startup.mbm<= format is different from a regular mbm.
means you found it. And the prog is ment to aniviewer.
Useing the PC, try this prog Xnview
