By default, tips are on, but they interupt play. It says you can disable tips in My FIFA 08, but I cannot find how. Anyone else with this minor niggle?
FIFA 08 Ngage disable tips
yeah, that was annoying. I stopped getting tips when playing a season though so maybe it gives you tips for the frist say 5 games then packs in??
Select My Fifa 08
Select Tutorial Settings
Select Tutorial Display -> Off
Job done. 😊
Dancing Badger wrote:Select My Fifa 08
Select Tutorial Display -> OffJob done. 😊
Yup, ditto 😊 Beat me to it 😉
Cheers to you both, simple when you think about it!
