Hi,My problem is that even though I have paired my car stereo with the 6120 classic and it connects when I start the car,every time an incoming call comes in on the mobile it doesn't automatically come through the car sound system.Instead a message comes up on the mobile for Handset or My Car and you have to choose one on the mobile before you can take the call.Its the same when making outgoing calls on the phone when it is connected to the car system.This obviously isn't practical as the whole idea of handsfree is that you don't have to look for your phone when driving.I have a SE W660i which is also paired with the car system and when it is connected all calls go through the car system automatically.Does anyone have any suggestions?Does anyone know if there is a setting on the phone that I can change to sort this out?All help greatly appreciated.thanks.
Bluetooth probs with nokia 6120C
New firmware will fix this problem, my wife has the same phone and same problem. I updated the firmware through NSU and since then it's been fine.
Robski
Robski,thanks for your reply,i'm a bit of a novice to this,how do i get my hands on this firmware?through NSU?what does this mean?Thanks again.
banner09 wrote:Robski,thanks for your reply,i'm a bit of a novice to this,how do i get my hands on this firmware?through NSU?what does this mean?Thanks again.
No problem mate, you should have got Nokia PC Suite when you got the phone. When thats installed you click on update firmware / software and away you go. Make sure the phone has full battery when you go through the steps though.
If you haven't got that program just go to the nokia site and download it.
Cheers Robski
Thanks again,I'll give that a go and let you know how it goes.
How do you get this to work? i have the same problem when connecting to my handsfree tomtom, now my firmware is version 3.70, when i use NSU, it tells me that 3.70 is the latest version, i know this not to be true because i have read forums where ppl have installed later (up to 4.8??) version... i really need this to work? this is driving me crazy 😞
