Anyone here syncing the P800 to Lotus Notes?
I am using PC Suite 1.1.1 and cannot get the calendar entries to sync from Notes into the P800. Entries do go from the P800 to Notes.
Calendar sync works fine with Outlook.
Any ideas what may be going wrong?
does your outlook sync the events in the calendar to the P800?
[quote="guest"]does your outlook sync the events in the calendar to the P800?[/quote]
mine sure doesn't 😞
I'm waiting for the day iSync supports the SE P800...
Mark
yes I can get calendar items in Outlook to sync into the P800 - unless you are referring to whole day events in which case I do see problems
😞 I having a problem... the time shifts after/during a sync... for example if the appointment is for 11am in Outlook, it shows up as 10am in the P800. I've checked that the time zones are the same on the PC and the P800... any other suggestions?
[quote="sreece"]😞 I having a problem... the time shifts after/during a sync... for example if the appointment is for 11am in Outlook, it shows up as 10am in the P800. I've checked that the time zones are the same on the PC and the P800... any other suggestions?[/quote]
This is a known issue if you are synchronizing against MS Exchange. MS Exchange - that is the OS Exchange runs un - have to have the correct time zone set!
Hey,
Yes i have the same problem. The stupid software does not read the Notes Calender. I have used the "Master Reset" on the phone (so I lost everything) and then also reinstalled the 1.1.1 sync version on the computer. The Notes version is the same 5.0.8 and it worked with the old sync version.
This time I have only activated the calender sync but no bonus.
Can we PLEASE have an updated version to fix this
/Jake 😮
[quote="colinq"]Anyone here syncing the P800 to Lotus Notes?
Any ideas what may be going wrong?[/quote]
Sorry 4 bad English...
If it helps...
I`m syncin` with Lotus Organizer.
There was 2 problems: Error "Can`t find folder", and NULL sync after long time.
First problem was killed by creating empty "Planner" section for syncin`
Second - by limitin` of the record to sync.
