Hi all.
My frend have delited alle contacts and calender eitems.
Is there any way to restore them?
Regards Henrik
Hi all.
Regards Henrik
cpq wrote:Hi all.My frend have delited alle contacts and calender eitems.
Regards Henrik
You have several options, but only if you have copies of the information...
1. Restore a recent PC Suite Backup (Content Copier)
2. Restore a recent backup taken with the Memory Card Tool.
3. Synchronise the N95 and MS Outlook using PC Suite Synchronisation.
If you don't have any of these options, then you have probably permanently lost your contacts info and will need to manually re-enter the data.
