Hi, i tried to install the apps but ben i go on menu/download i can't find winlive even if i do a refresh... is there any way to get that apps??
Thx
Thx
Thx dude it worked...
Glad I could be of help.
I don't want open another thread for that but i've got last question for you maybe you can help me...
I upgraded to the new firmware but when i want to change on the silent mode by pressing # it doesnt work anymore...
I had a similar problem until I did a factory reset and then reinstalled everything from backup EXCEPT "Settings." Works fine now.
