I've been reading tons of reviews on the cases after I got my n95-3. However I couldn't find anyone who had experience with this one:
[SPAM removed]
can anyone tell me if this will fit a n95-3 and if anyone's tried it? Thanks so much!
[SPAM removed]
i like. does it clip on or is a replacement cover for the back?
I like it too. Judging by the back there is no battery cover which suggests its a clip on cover.
it would be a definite improvement over the crystal case.
It shows an N95 8GB in piccy yet doesnt state in the wording.
Anyone confirm if its N95 cassic or N95 8gb?
On ebay atm.
i like it even more now i have seen that pic, how much is it on Ebay?
Can you buy these in the uk? Seems to be us only?
Casperuk wrote:i like it even more now i have seen that pic, how much is it on Ebay?
Well they are �5 all in but from china. just got a look at one with better pictures and it looks like a crystal case with a wafer thin coating of aluminum.
Question is how will it fit and how much more bulky will it make your n95.
Will keep my aye out if any are sellin in UK PLUS no nokia wording N95 top left of front etc etc.
D4n958GB wrote:Can you buy these in the uk? Seems to be us only?
One quick search for "N95" and "aluminium" resulted in this
it is only for n95? It shows an N95 8GB but does it fit?
i found this in the description:
"Compatible with NOKIA N95 STANDARD, not for 8G"
jennyyu wrote:I've been reading tons of reviews on the cases after I got my n95-3. However I couldn't find anyone who had experience with this one:
[SPAM removed]can anyone tell me if this will fit a n95-3 and if anyone's tried it? Thanks so much!
it fits n95-3.
i think it is the best case i ever tried on my N95.
The original leather case from Nokia is very nice, but does not protects too much when it's opened.
The crystal cases are too cheap and fragile.
The rubberized cases are better than the crystal ones, but still fragile (two months and they're broken).
mine with it:
Considering both windy01 and jennyyu have the same IP address, I would recommend people stay away from buying this, and I shall remove all links from their posts.
Your not allowed to have mulitple IDs and especially not allowed to pimp something as a customer rather than being the actual seller.
cracking spot.
looking at the picys it looks like it's a crystal case with a metal shell. most likely to fall apart like the crystal cases
I was suspicous at 'her' first post. I dont think I have ever seen a first post with a link like that in it to be real. Still, I give people the benefit of doubt but in this case they were stupid enough to join up under a new name on the same IP.
Any future postings from first timers advertising that site will be automatically banned from now on.
Looking at the actual product, any benefit in the strength of the metal (which, I bet isnt aluminuim) is negated by rather poor looking joins to the plastic. Those joins will likely break very easily after a few knocks.
it's a shame cos an all metal case would be cracking
Casperuk wrote:it's a shame cos an all metal case would be cracking
Aye, its something i spotted too considering where they were coming from.
