If I move my calendar to D: will synchronizing with Outlook still work normally?
Moving calendar to D & syncing
The only thing you should do, is statr you PC Suite and the edit the task where calendar is syncronized to use new calendar file, not the default one.(original in c:\system\data)
isto
Ahhhh thanks! 😃
I suppose that was pretty obvious but.. :roll:
Anyway, all in order now!
I moved my calendar to d...much better if a bit slower...just give pc suite the right directory and you're gonna be ok!!!
Ok.. I have another question, probably as obvious as the previous one but I cannot figure it out, please be patient.. 😮ops:
I moved my calendar to D: and I can sync it now but when I press the calendar key in the communicator, it opens a blank calendar.
Now, I can link my calendar in D drive to desk, but how do I make it open with the calendar key?
It's not possible...you press calendar key - menu - other options - open calendar - then you browse through all the folders and find your calendar and open it! Ok?
