7560 Calander/Tasks Sync Failure
1 replies · 1,647 views · Started 04 February 2003
Hi
Using Outlook 2000 on Win 2000, and ran the setup for contacts, calander and task replication. Not disimilar to the Nokia suite for the 6210, so no worries.
All sync'd fine the 1st time, and after some name editing (Surname first name problem), all seemed fine.
But when I sync now, Contacts are fine, but tasks and calander fail. The Phone has an error: "App. closed ectcpadapter_0 0808E5C KERN-EXEC 3"
I've installed:
Hearts, Keylock, mines, miniGPS, nameswap (now removed), sdoubler, sSaver and Triz (Tetris).
Any connection/experience of this error ?
I don;t want to have to remove all these, and re-install one at a time....
(I tried searching AAS, but no luck.)
Cheers
En Croute
Hi, not much help, but I'm having problems importing data into the calendar. So maybe the problem is the calendar.
Anybody out there with knowledge of how Calendar works (or an alternative app??)?
Paul
