Hi guys...
I just Upgrade a new firmware from V 10.0.018 If I'm not wrong to V 21.0.016 ..
Ok..I just explore thatit's so many improvement...more faster...but something Missing..If I open a cover lens of camera, Light in the bottom camera seems like death...My questions is...Is my phone seems like 'broke' or bugs of the firmware?? please let me know... Thanks for u guys..
Sorry for bad english...
Regard
Julius
Another thing I noticed with the new firmware (maybe im missing something).....
when you do a slideshow, it no longer does the cool zooming effect with the pics 😮
codiac wrote:Another thing I noticed with the new firmware (maybe im missing something).....when you do a slideshow, it no longer does the cool zooming effect with the pics 😮
Mine zooms are you sure you have the effect turned on under slide show settings
Ques: did you perform a FULL restore maybe ?
If so: than that maybe the problem! A lot has changed, esp. Memory Management . . .
Best is: Do a CLEAN install, backup/restore ONLY your contacts/agenda, and perform a CLEAN installation of your programs . . . :icon4:
hippyguyman wrote:Mine zooms are you sure you have the effect turned on under slide show settings
Ok sussed it...
Just checked my settings again and the option is there again :icon14:
Now I noticed it wasn't there when I plugged the phone into my TV. Just checked again and the option disappears as soon as you plug in, even if you start a slideshow with the zooming on, it stops and switches to normal when you plug the cable in :icon13:
Can anyone else test this?, maybe its just my phone :con?
codiac wrote:Ok sussed it...Just checked my settings again and the option is there again :icon14:
Yea the zoom option does disapear once connected to a TV
I know it used to work on previous firmware versions, wonder if its a bug or a "feature" change?
