Nokia 9300, How to use it
2 replies · 2,283 views · Started 10 May 2008
I have bought second hand nokia 9300 phone just the phone for 40$ in India and I just use it as a normal phone. I would like to know if I dont have a datacable and a CD can I connect my phone with the computer through bluetooth. If yes then how and should there be any software to get connected to the computer.
If you don't have the CD, you can download the latest Nokia software from the support pages of their website.
Yes, you can connect Nokia DataSuite to your phone via Bluetooth, but be advised that BT connections are not very suitable for transferring large amounts of data as the data rate is much slower than a direct hardwired connection.
The data cables may be easily obtained over the internet or directly from Nokia.
That's right.
Actually you can use your phone without the Nokia software as well. It's possible to copy, delete files on your device and sync your calendar and contacts, but the Nokia Pc Suite is in fact more customizable and useful.
So that is wat you need: Nokia Pc Suite!
Cheers,
