Hello everyone,
I am experiencing some difficulties having the walkman playback through a Bluetooth headset (Motorola HS810). It can be paired with my phone but having trouble with just getting playback through the headset.
I was wondering what else the problem can be? :con?
The headset works as I can receive playback on Bluetooth through my laptop.
Wonder what the problem could be??? :con?
Anyone know of a solution to resolve this issue? :con?
Regards
Dave 😊
are you transfering the sound to the headset via the menu options?
No just tryin to simple transfer the sound within the walkman application and doesn't find the headset,
does it show up as being paired ok in the bluetooth app? should be in the audio enabled devices tab.
if its not my devices tab at all then its not pairing correctly
Yes its paired within the bluetooth application and has the enable as audio selected.
Regards
Dave
hmm thats strange, u should just select more, settings, transer sound and select your headset, is the music playing before you transfer it you get an error if not
have tried it the way you have described but doesnt dispaly the headset.
plug in the wired headset and then connect the bluetooth headset then see if the radio app sees it
just tried it and didnt work..
hmm must be something wierd with your headset.. i have a motorola S9 and that works fine :con?
Is there anything else to try apart from a different headset??
