E90 as a BlackBerry terminal on a Black Berry Enterprise Server
6 replies · 12,258 views · Started 11 May 2008
I would like to know if the E90 supports to work well with the push mail from a Black Berry Enterprise Server (BES)?
are there sometimes sychronisation or other problemes ?
How can I switch from a BlackBerry handheld Curve to a Nokia E90 (only change the sim and configure mail in the E90 or) should I ask to the IT manager to activate the E90 device by air?
from a E90 newbie
I believe BES only works with Blackberry devices - to work with other devices I believe you need Blackberry connect.
Yes black berry connect 4.0 exist for E90 but I would like to verify if some one has experience with.
I use now a BB Curve connected to a BES sins 2 weeks. I miss my Nokia 9500 !
Looking for a E90, I wonder if the E90 works well with the BB Connect to a BES
If there is some one who use a E90 connected to a BES I ' m glad to know his /her experience.
Carlo
I am currently trying to activate an e90 on a BES server at my work and I am having trouble activating it. Im using steps from this link: http://www.nehmewalid.com/latest/blackberry-on-nokia-e90.html
The device will fail the activation process. Im using Nokia S60 BlackBerry Connect 4.0 vers. 7.45.1(.SISX, 2,89 MB) version 7.40.1.2 on your device and am having no luck. I get the standard "your account is not authorised for Enterprise Activation. Contact your IT Administrator." Message.
I know the device reaches the server because when I dont use a activation password it says an error about the password being not found. I will post more If I get any further. Thanks.
hi there,
I am working with BB Connect 4.0 on a BES.
It is working great all over the globe.
The only thing I miss is the BB messenger service to send PIN messages.
Up until now I can only receive PIN messages and not send them.
Anyone have an idea ?
Thanks,
Eric
Hello All,
i'm using the blackberry connect service on my e90 and it works very well all over the world
something you might be struggling with is the version of blackberry connect software make sure you have the correct version depending on the software level on your device
Andy...
ericlecarde wrote:I am currently trying to activate an e90 on a BES server at my work and I am having trouble activating it. Im using steps from this link: http://www.nehmewalid.com/latest/blackberry-on-nokia-e90.html
Please send me the bb connect 4.0 software . My work is getting hampered without it .Please send it to me immediately .I'll be thankfull if you will do the needfull.
I am from india
