How to put clips off your coumpter onto your memory card - ( Nokia N95 8GB )
6 replies · 3,760 views · Started 14 May 2008
Hi
To be honest.....i have 4 pictures
and 8 songs on my phone so far....
i try to put a clip of lee evans
and it says i dont have enough room......
so im wondering.....maybe it is
trying to put it into the phone part
and not the memory card part...
cause the memory card part would have all the
space to put things onto
any ideas?
connect you phone to pc indata transfer mode/mass storage mode and the phone gets detected as a flash memory drive.
then just transfer the stuff like that'
or in PC suite mode click on file browser and select your folder and copy paste it or use nokia music/video transfer app and convert and send.just chose the save path
theres lots of ways to send files to mass storage
Its all there on the files on my coumpter but on my phone i can find it where i put it and i no the exact position wer i stuck it
But how do i move them to my music player.....
At the minuite my songs are in
Tools > File mgr. > (Memorycard bit) > Music....
But when i click move songs or what ever
i dont no where to go to?....
could you tell me?
you connect the phone to the computer with USB cable in DATA TRANSFER mode. open up MY COMPUTER, open the memory card, create a new folder called whatever you want. drag and drop the videos and music in there. then use your file browser to find the videos on the phone and play them.
when i transfer with nokia music manager they get put in
e./Sound clips/digital sounds
in the mass memory which is the default path pre-chosen,but you can choose your own path in the new music manager if you want to transfer to a fold made by yourself
the exact same folder named the above exist on phone memory too so check there if they are not in the mass memory Sound clips folder and you'll kmow then if they are getting transfered to wrong memory
