N95 v21 keeps restarting itself
5 replies · 5,577 views · Started 14 May 2008
So I have a generic N95 ver21 firmware. When ever I use wwigo the phone will restart after a unspecified amount of time. This also happened after a couple of minutes of playing a video in mobitubia too.
The apps were installed on the memory card so Ive reinstalled them on the phone and have yet to try them out, but has anyone else found out this problem?
Could it be heat related causing the phone to over heat and subsequently restart?
Still no joy when the applications are installed on the phone memory.
Any ideas? Ive reformatted the phone already and its still doing it 😞
tried that already. I did backup and restore everything though aswell, maybe theres a setting I have used that is causing this so its essentially the same as before the flash. Ill try another format and not use restore
The most thorough method, albeit time consuming, is to uninstall everything (apps, themes, music, videos, etc) reformat the memory card, re-flash the phone and then re-install everything. It's the only surefire method, to be honest. If there's something gone squiffy in your backup, you're only going to be restoring it everytime. I only ever backup contacts, calendar and notes.
arrrghh I was testing it out for a while, everything was going great and then it restarted itself again. Im wondering if its something to do with service pack 3 on XP or something, nothings changed with the phone. :/
