Some Help Please...
1 replies · 1,694 views · Started 15 May 2008
I know this has been posted many times, and i have searched, but all topics are outdated
I want to convert videos and dvds to play on the big screen in the highest quality. I have downloaded Super and tried to follow the settings i found on this forum but it seems the program has been updated since the settings provided in the thread i read dont match with the setting options on the current Super edition. I have also downloaded mediacoder and the e90 setting but the output files wont play on my e90 (i can only get audio)
is ther any up to date and recent "how to" for this issue?
Thanks guys
I suggest You to try one more time mediacoder.
I've posted before this already and i've even put my settings for e90 available to download but mediacoder developed in the meantime and when you load the settings it just won't make the picture, only audio.
To make mediacoder to work you have to set a few things only:
- audio encode set to Nero Encoder
- video tab: format Xvid, container mp4, source MPlayer and backend auto select
- picture tab: resize on, 800x352, crop manual (use cropper to make sure it will be the way you expect.) the rest don't change.
It should work like this
Cheers
