I share my pc's internet connection for quiete a while now.
I used an acces point called INET PC Sharing with the following settings:
Name: INET PC Sharing
Type: GPRS
Name accespoint: None
Username: None
Ask pw: NO
pw: **** (Standard)
Verification: Normal
IP-adress gateway: 0.0.0.0
Everything went well. I was able to use TipicMe and send and receive mails, surf the net and so on.
But yesterday i received an automatic confirmationmessage for MMS from my operator (Mobistar Belgium).
Now when i save this messag it creates an extra accespoint called Mobistar MMS. I configure my Multimedia-messages settings and yes finaly I can send MMS files.
BUT now all applications try to connect with these settings and of course it all fails! All applications and mailboxes have INET PC Share accespoint selected but they keep trying to connect with a regular GPRS connection instead of the "fake" Internet schare connection. Even when I delete the mobistar MMS acces point, they now keep trying to connect GPRS instead of my internet sharing 😞 How does this happen? Nothing works now. Sometimes, after deleting MMS mobistar accespoint and several reboots, Tipicme uses the INET PC Sharing connection but this doesn't happen much. All applications mostly try using regular GPRS connection even with the accespoint of mobistar deleted. Also manual configuration of MMS doesn't work.
What can I do about this? How can I use both connections at the same time (eg: INET PC Share connection fot TIPICME and mail and so on, and the Mobistar MMS accespoint for sending MMS messages only.)
Thanx alot,
Boeky.
