Connection selection
4 replies · 3,740 views · Started 17 May 2008
How so I get Symbian to remember my selection?
Just about every app I use asks if it can access the internet, then asks me to chose the connection. Why?
The answer is always yes and t-mobile internet - The first time I use an app it's reasonable to ask but surely after that they should remember my settings and use them (unless a LAN is available when they should use that).
Am I missing a setting somewhere?
Also, when downloading apps it adds a few more steps - eg asking if I want to download the app THEN asking if I want to connect to the internet then asking me to chose the connection then downloading the app then telling me the flippin version number and asking if I want to install - why SO many steps. With WinMo it was ussually 2 steps - telling it you want the app then confirming where you wanted it installed.
I'm sure I'm just missing the setting that says - 'Ask lots of stupid questions yes/no'
I'm afraid not - that's one of the (few) downsides when compared with WinMo.
Remember the big upside though - no more "it's very reliable, I only have to soft reset it a few times a day"
Terry1100 wrote:I'm afraid not - that's one of the (few) downsides when compared with WinMo.
WinMo 6 is VERY reliable, I can't remember the last time I had to do a reset.
And push email 'just works' with WM.
I love the form factor of the e90 and will probably get used to it, but I loved the flexibility of WM and the large screen on my Athena.
To do what your asking you must go into the applications settings and change the settings (likely under "connection"😉 from always ask to t-mobile data, unfortunately i have yet to see a setting that allows for a primary and secondary connection option, so youll have to just set it for tmobile data and if you really care enough to change it manually switch it when your in wifi range
