Couple of questions
1 replies · 2,313 views · Started 19 May 2008
Hi guys,
just got a couple of questions to ask:
1) Is there an app that locks the keypad with a PIN number or password?
2) Is there a way to password protect files and folders on the mass memory of my N95 8Gb?
3) I can't seem to delete picture messages. Everytime I try I get an error message 'Already in Use'. In order to remove them I have to restart my phone and delete the picture message before accessing anything else. I have an inkling it may be something to do with the conversation app. Anyone else experienced this or have a solution?
8Ball
Hi 8Ball!
8Ball wrote:1) Is there an app that locks the keypad with a PIN number or password?
Press the power button briefly and select "Lock phone". Default security code is 12345.
8Ball wrote:2) Is there a way to password protect files and folders on the mass memory of my N95 8Gb?
You could use the inbuilt Zip application to add files and folders to a zip file to which you can then add a password, and then delete the original files. There are many other apps (such as Best Crypto for one) that allow far more flexibility.
8Ball wrote:3) I can't seem to delete picture messages. Everytime I try I get an error message 'Already in Use'. In order to remove them I have to restart my phone and delete the picture message before accessing anything else. I have an inkling it may be something to do with the conversation app. Anyone else experienced this or have a solution?
Sorry, I haven't a clue!
