Walkinghotspot & Wii
2 replies · 2,313 views · Started 20 May 2008
Has anyone been able to connect a wii to walkinghotspot on their N95? I don't know if this is possible as all the support docs refer to routers. I tried and detected my walkinghotspot network but was unable to connect (error 51300). Any ideas or should I just give up!?
If you have previously had some other equipment connected to WalkingHotSpot you need to contact the developer.
The limitation of the trial version is that you can only connect ONE piece of equipment - the first one you connect.
