P800 touch screen only works with button depressed
2 replies · 5,119 views · Started 21 May 2008
Hi can someone help
I was gently cleaning my p800 screen while it was on, when it decided it would no longer act as a touch screen, I have discovered if hold the toggle button down it operates correctly.
Does anyone know what to do? Should I do a master reset?
I have tried a master reset, no change
However a fully charged battery emptied within 3 hours so the touch screen must be in some constant state of being actively depressed, any one have any clues at all?
sghg77 wrote:I have tried a master reset, no change
check - clean - resolder LCD connector and touch screen 4 contect at lcd flax.
wbr
