Has arrived at http://www.ereader.com/ereader/software/product/download/18842/eReader%20Pro%203.0.3%20for%20Symbian%2060%20r3.zip
Unfortunately, I can't open any of my books as they don't appear in the Bookshelf. Presumably I need to copy them into a special folder, but I have tried the obvious one like eBooks. Anyone got any ideas? Needless to say the README and FAQ don't mention this vital bit of information.
Ian.
I received instructions from eReader/FictionWise and they worked on my Nokia N82. Here they are. Good luck, endre
This is what the README should have stated:
Installing eReader Books:
- Nokia 3250, E50, E61i, E62, N73, N75, N91, N93, N82 and other 3rd
edition phones
* If you have not done so, please install the PC Suite software
included on the CD that came with the phone. If you don?t have
the CD or the software, you can download it at
http://www.nokiausa.com/A4735050.
* Follow the instructions in PC Suite and your phone's user guide
for establishing a connection with your device.
* Run the Nokia PC Suite. * Select "Transfer Files" or "File
Manager".
* Browse to the location of your eBook and select copy on the .pdb
file.
* Click on the folder for your device (e.g. Nokia E50) from
the Nokia Phone Browser. Browse to "Phone Memory"->Data->Others
or "Memory Card"->Data->Others.
* Paste the eBook in the selected folder.
Thanks pasting it into Data/Others worked. GOK why they can't make the folder configurable.
Ian.
