Once having a GPRS account you can't use bluetooth internet?
2 replies · 10,354 views · Started 05 February 2003
Hi
I used to share internet with a fake acces point:
Name: INET PC Sharing
Type: GPRS
Name accespoint: None
Username: None
Ask pw: NO
pw: **** (Standard)
Verification: Normal
IP-adress gateway: 0.0.0.0
It used bluetooth and mrouter to share my pc's internet connection.
It never showed the G icon in the left upper corner.
Now after configuration of another GPRS acces point (Mobistar), suddenly the INET PC Sharing accespoint tries to use the regualar GPRS connection and it doesn't use the Bluetooh connection (wich is active when I try) It's like once set a real GPRS accespoint, the fake one (INET PC Sharing) that connected to internet over bluetooth, doesn't work anymore and tries to use a real GPRS connection.
How can I solve this problem? Can't I share internet anymore once having set a real GPRS accespoint.
Can anyone that has an GPRS account tell me how to share internet over bluetooth then?
This wil solve my other problem too:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=7550
Thanx a lot
Boeky.
I have the same problem as well. Just delete your new GPRS access point, your 'fake' one will work again without a 'G' sign. but the trouble is you have to do it everytime if you want to swtich between two access points😞
