E61i - Customising the desktop icons ..
1 replies · 7,337 views · Started 23 May 2008
Hi Guys,
I realise I can go to tools, settings, phone, standby mode and then Active Standby apps. This allows me to change the icons on the strip across the desktop BUT only to preset internal app icons.
what I want to know is IF I install an app like Fring, how would I add an Icon for this app to the desktop?
Cheers
Aidan
Once you install any applications it will automatically add it in the list, same applies for fring. once u install it, go to change the stanby applications list and scroll thru, u will find it.
