Hi...I was playing around with my 9210i 2 days ago and I noticed that filemanager creats by itself a folder "documents" without any reason! Every time I cancel it and re-boot,the same folder is there again!!!It is pissing me off!!! :evil: :evil: :x ...Does anybody know why this happens? I am about to format but I don't wanna do it just for this reason. I believe I have done something without knowing what I was doing... 😮ops:
Thanx.... 😃
check under control panell what settings do you have regarding the 9210 default Document folder.
Switch it to d
Done it...I'll tell you in a while!!
don't think this is caused by filemanager ... I think Symbian os creates this map
I saw it happening on almost every other 9210 I've seen till now!!! :-? Is there a way of getting rid of this?
nope, don't think it's that bad ... It's like windows that can't live without "my documents"
I'm about to format!!It's so anoying!!! :evil: :x
Btw...could you please give me instructions on how to install the back-up files of my 9210i from pc suite to communicator? I have formatted in the past but instead of transfering the back-up files i did in pc suite I had another mmc which contained all my docs and contact etc!!
THANKS
It is not happening on Mine.
As I told you, set the Defaul Folder from control panell on D:
Go to file manager after a restart and delete the C: anoying documents folder.
Do I have to repeat for the 3-rd time?
[quote="TheSpecialBoy"]It is not happening on Mine.
😉[/quote]
Probably for the 4th... 😃 😃 :angel:
Dear Thespecialboy I've done as you told me but nothing,still the same thing!!!
It is continuing to do this!!!!!!!!!!!!!!!Any advice???
[quote="The Godfather"]It is continuing to do this!!!!!!!!!!!!!!!Any advice???[/quote]
Go to Control Panel and change "Default folder" to something else (exisitng).
Yeah...it seemed to have stopped!Thank you guys...!!!!!!!!!!!!! :P
