Hi
I am using NOKIA E70 model.While connecting to gprs i am getting error 734 ppp link.
what i suppose to do?
and will the settings will work for any service provider or i suppose to change it in roaming.
If possible pl suggest me universal settings as i am having marketing job i am always roaming.
Thanks & Regards
Anand
The easiest way to do this is to have your service provider send you an SMS with the required settings, when you receive this SMS the phone will ask whether you want to save and apply the settings - do so and you're all set.
Settings will be different between service providers so there are no "universal" settings.
As for roaming, if your gprs package allows it then there is no need to change settings when roaming.
