If you see THIS on your 3650, you're in serious trouble
12 replies · 4,283 views · Started 05 February 2003
Unfortunately I already saw it on two 3650 which have been patched to english OS 1.34. So here's again the warning: PLEASE be careful how you install programs and which programs you install. Some of you guys don't take it seriously but when shit happens, it happens. 😉
I was receiving this error as well, although it didn't occur from installing apps, rather when I had my GPRS settings as follows:
GPRS Connection: When available
If I had the above setting entered, and there was a 'valid' gprs signal (denoted by the "G"😉, when I would shut the phone down, I would get a similar fault. Since then, I just keep the GPRS Connection as: When Needed.
-kenny g
[quote="judell74"]I had this once. I remove the battery and restart the phone and up to now my phone works great![/quote]
Trust me, you had NOT that message. There are other error messages like that (looking almost the same) which aren't that bad. For example when you install the Nancy stuff. If you ever see THIS message, your phone is DEAD. You need a new software written to it. Oh boy, you guys really have problems with understanding. :roll:
[quote="Nokker"]PLEASE be careful how you install programs and which programs you install. Some of you guys don't take it seriously but when shit happens, it happens. 😉[/quote]
Nokker,
So how should we be installing programs and also how do we determine which ones not to install on our 3650s?
Nokker, So how should we be installing programs and also how do we determine which ones not to install on our 3650s?
Unfortunately this is like a lottery game: you can win or not. 😞
The best thing to do is to install every program seperately, means: restarting the phone after EACH and SINGLE program install.
Also avoid beta versions of programs or programs which target specifically some internal routines of the phone. Using the latest version of each program is also a very good idea because some developers already have the 3650 or at least the SDK for testing.
I just wanted to help, if somebody thinks he doesn't care...that's fine to me. I have my phone, it works with all programs I need now and this is what counts for me. 😊
I have the following programs installed (latest versions!):
- Handsafe
- MiniGPS
- Camera FX
- eFile Manager
- SmartCrypt
I licensed all these programs, just in case somebody thinks... :angel:
All the above mentioned programs work fine with V 1.34.
I had problems with Nancy and another program I don't remember anymore (install went fine but after restarting the phone, I got the "green screen"😉.
yup, how do we know if the program is okay to install and how are we going to install it to avoid getting such error?
[quote="amor7"]yup, how do we know if the program is okay to install and how are we going to install it to avoid getting such error?[/quote]
As I said...it is like a lottery...you can win or not. :cry:
I remember now which program also made problems: ActiveMail.
yup i have that 4 times, with 2x with Nancy, and the 2nd time my fone wont boot up, rested it for a minute and i booted up normally...
[quote="Anonymous"]yup i have that 4 times, with 2x with Nancy, and the 2nd time my fone wont boot up, rested it for a minute and i booted up normally...[/quote]
I give it up. :silly:
if the loaded software messes with the flashed data you have a dead phone. Get the idea.
goboy has done this two me once, but I got a command prompt! keypad didn't work though 😞
>c:
pulling the battery did clear the fault though.
It's ok, if it has Nokia OK acceptance. Quite simple.
