Hello all this is my first post on all about symbian i hope its of some help.
I recently purchased a 3 network N95-2 8GB online and hated all the silly 3 features it had so i set forth to remove the old firmware (15.00.15) and replacing it with the updated V20.0.016 Firmware!!!
Things you need:
1.Updated version of Nokia Update service from the nokia website.
2. Nemises service suite
Both can be easily googled and downloaded.
Steps to debranding and updating
Please note complete this task at your own risk it could completly stuff your phone (brick it)
Steps to debranding
1. Ensure your phone is fully charged and connect it via the usb port of your pc.
2.After installing nemesis service suit open and click scan for new device in the top right corner.
3.Click the "phone" Tab
4.Click on the "Read" button. The product code along with the other codes should now be visible.
5. Find the product code box to the right and click the enable box now it is very important that you find the correct product code you cannot use just a normal N95 Code it must be and N95 8GB Code. I used 0550453 the australian code as i live in australia i thought it would be safest.
Note N95 8GB Product codes below.
6.Once you have selected a product code copy it to the product code box in nemesis service suite with the tickbox enabled and click write! It is now safe to close nemesis.
7.Run the Nokia update service as per normal following all intructions as directed.
8.Thats it and your done!!!
9. Note that if you wish to complete this task all Three network Branding will be removed and no Three options with be avialable to the phone anymore.
N95 8GB product codes
0550348 - FRANCE
0550352 - ALPS
0549487 - EURO1
0550359 - EURO2
0550370 - TURKEY
0550372 - SCANDINAVIA
0550373 - BALTIAN
0550798 - RUSSIAN
0550799 - UKRAINE
0550800 - BELARUS/MOLDOVA
0550375 - CIS, Bulgaria
0550378 - EURO3
0550379 - BALKANS
0550801 - GREECE, CYPROS
0550802 - ISRAEL
0555180 - SINGAPORE
0555181 - MALAYSIA
0555187 - EMERGING ASIA
0550455 - INDONESIA
0550454 - NEW ZEALAND
0550453 - AUSTRALIA
0550459 - THAILAND
0550457 - VIETNAM
0557980 - HONG KONG / CHINA
0557877 - MALASIA
0550388 - AFRICA (NIGERIA)
N95 8GB Operator Specific codes
0558166 - SFR France
Note Complete this task at your own risk i will not be held responsible for any dammage caused to your phone.
After the update is complete you will notice a vast improvement is speed quality of the phone.
Just as i did!😊
Regards
knoxy42
