Hey guys,
After updating to the new firmware I am no longer able to open my contacts on the front screen. I have to open the flip in order to launch contacts??
I was reading on n forum that it may be caused by restoring a back up, but this is not the case for me. I did not restore anything and have just manually re installed my apps. The only programs I have installed are MFE, google maps, and google search.
Do you guys think that it may be something with MFE? Maybe the new firmware is conflicting with it somehow. i dont know, but it is driving my crazy. I already did a hard reset, on the device and the problem still persists.
Any help or advice would be greatly appreciated.
Thanks!
That sounds dodgy to me, i would re-install the upgrade again, and check it before installing or restoring anything. Then install apps one by one. To be honest if you've done a hard reset and that didn't work, the only option you still have is as i've suggested. back to NSU and you sould get the option to re-install again.
clive6630 wrote:That sounds dodgy to me, i would re-install the upgrade again, and check it before installing or restoring anything. Then install apps one by one. To be honest if you've done a hard reset and that didn't work, the only option you still have is as i've suggested. back to NSU and you sould get the option to re-install again.
I just did another hard reset, and so far so good. Hopefully it wont happen again, if it does I am going to just reload the firmware.
after upgrading your FW is needed to:
1- *#7370# reset device to defaults
2- restore using nokia content copier..
than the contacts are working 😉
ciao
