smashing price for this, good for ur n95's
http://www.mymemory.co.uk/Micro-SDHC/SanDisk/SanDisk-8GB-Micro-SD-(SDHC)-Card---Class-4
That is a good price, and I'm looking to replace my current 2Gb card. I'm sure someone out there has done this before - is it as simple as copying the content of my current card to a new one, or do all the apps on the card have to be re-installed?
Usually, its fine just to copy it across, as long as you make sure all hidden folders and files are shown when you copy it across.
deebr wrote:That is a good price, and I'm looking to replace my current 2Gb card. I'm sure someone out there has done this before - is it as simple as copying the content of my current card to a new one, or do all the apps on the card have to be re-installed?
A straight copy worked fine for me. But as stated above, make sure you get EVERYTHING across.
Lynchy wrote:smashing price for this, good for ur n95'shttp://www.mymemory.co.uk/Micro-SDHC/SanDisk/SanDisk-8GB-Micro-SD-(SDHC)-Card---Class-4
...cheers for that Lynchy :icon14:...just bagged meself one.
Yes another thumbs up :icon14: from me, great find I have just bagged two 😊
glad its some use , seemed a good price :icon14:
the card reader you get with it is a good bonus too
Lynchy wrote:the card reader you get with it is a good bonus too
I've got one of those. They're tiny and work very well. It effectively turns the card into a USB drive.
Damn, just went to order 1 and they are out of stock :frown:
These cards are back in stock 😉
wow thanks for this been looking for a cheap one for for ages :icon14:
