I was just wondeirng if there was any way you could extend the ringing time on the N95 so it takes longer for voicemail to pop up on the callers phone?
Thanks.
Thanks.
The_2nd_Runner wrote:I was just wondeirng if there was any way you could extend the ringing time on the N95 so it takes longer for voicemail to pop up on the callers phone?Thanks.
Isnt it dependant of cellular network provider?
Try this guide.
See number 14.
http://sjc-123.blogspot.com/2007/07/best-tips-and-tricks-for-nokia-n95-part.html
Wombler
yes it is dependent on the gsm network, and there are codes to enter that changes the network. i think longer ringing is one of the codes. but it has nothing to do with the n95, and any other phone you use on your account in the future will have the longer ring too.
Thanks for the replies, the link is quite helpful.
RogerPodacter wrote:yes it is dependent on the gsm network, and there are codes to enter that changes the network. i think longer ringing is one of the codes. but it has nothing to do with the n95, and any other phone you use on your account in the future will have the longer ring too.
It's an answer to his problem as opposed to a phone specific solution.
If it works on an N95 and solves the problem at hand then I can't see how that 'has nothing to do with the N95'.
These are network codes and I thought that was obvious but just to be crystal clear, yes they are phone independent.
Wombler
The_2nd_Runner wrote:Thanks for the replies, the link is quite helpful.
My pleasure and I hope it works for you.
I only discovered this site relatively recently via a link in this forum but it seems quite useful.
Wombler
you should or perhaps can change the delay time in your call divert options.
MENU > TOOLS > SETTINGS > PHONE > CALL DIVERT > VOICE CALLS > IF NOT ANSWERED > and select the delay you want. (i.e. how long it takes before it considers you not to be answering it.
kontraband wrote:you should or perhaps can change the delay time in your call divert options.MENU > TOOLS > SETTINGS > PHONE > CALL DIVERT > VOICE CALLS > IF NOT ANSWERED > and select the delay you want. (i.e. how long it takes before it considers you not to be answering it.
Good find!
It never ceases to amaze me the number of options hidden away on this phone.
Wombler
Wow! I assume it sends it by a short code to the swithc, but u re genius to find it there 😃 Thanks too! 😊
K.
