hey everyone im new to the n95 8gb. I was wondering is it possible to put a lock code key to open the gallery where videos and pictures are located? Any ideas..
is it possible to put a lock key on gallery?
A program called Advanced Device Locks allows you to lock the gallery and any other application you want
k thanks ill do a search and look for it. Do u happen to know if its free?
No it's not free I'm afraid
thanks works great
mattg64 wrote:A program called Advanced Device Locks allows you to lock the gallery and any other application you want
the gallery lets the nseries phones down big time. You put items in folders yet they dont actually move there, and locks should be standard!!!!
The only way I can think of to make sense of the gallery is to create albums for all different catagories and then just go to the appropriate album. I don't know if thats what the designers intended but it is somewhat effective.
As far as locking, the only solution I see is password protecting the memory card but I would think entering a password every time would get old fast.
i know wish it was standard..i had to pay the 11, it works good .. Worth it if u want ur stuff locked
tkboxer wrote:As far as locking, the only solution I see is password protecting the memory card but I would think entering a password every time would get old fast.
If you password protect your memory card you only have to put in a password if you put the card in another phone. You don't have to re-enter the password each time the card is accessed.
Liam548 wrote:the gallery lets the nseries phones down big time. You put items in folders yet they dont actually move there, and locks should be standard!!!!
It would be nice if you make an album for each catagory, you could choose an album from the folder from within the gallery without entering each folder through the computer....or can it be done?
BtG wrote:If you password protect your memory card you only have to put in a password if you put the card in another phone. You don't have to re-enter the password each time the card is accessed.
Ahhh! good to know, Thanks.
