I installed Nokia Maps 2.0 and at first I had no problems but now I am unable to see any maps within it...
I had the England map installed and added another country as I will be travelling soon and ever since I am unable to see any map data.
All i have on the screen is the green background and when I zoom out to the maximum I dont even have a planet earth anymore, just a black background!
The map for england is definitelly loaded and I have even tried reformatting my mmeory card and reloading it with no luck.
If I change the map mode to Hybrid the sattelite images download and display but I can never get any road data.
Anyone got any ideas how I can get the maps to appear again??:con?
having exactly same problem so await replies. have tried 2 cards,formatting them, loading via phone instead of card reader to no avail.
(australia map)
cheers
scott
got mine sorted, tried reformatting phone,card,reloading firmware.
in the end it seems to be purely the maps on the card. reloaded nokia maps 1.3.8 from a non nokia site and bingo it started working. not sure why, maybe others can tell us why. all i can offer is its a problem with the maps on your card, NOT the nokia mapz 2.0 or the phone itself.
try opening MAPS 2.0 without a card in there, can you zoon into the world map now?
i did this, put in a reformatted card,opened maps again with this card in phone. loaded MAP LOADER again and then loaded maps onto card again.
hope some of this helps.
scott
Thanks for that, got it working now. What a total pain!
back to where i began, got maps showing but in navigation mode it would get stuck in CALCULATING ROUTE forever.
so tried reloading maps again and now i cant get them back, i'm a bit over it, might try reinstalling maps 1,at least it worked....
