If you have any questions about the Nokia N78 please let me know and I (or someone else) will do our best to get them answered.
Rafe
Links of Interest:
N78 Gallery
N78 Preview
Rafe
Links of Interest:
N78 Gallery
N78 Preview
Some questions answered here:
http://www.allaboutsymbian.com/forum//forum/thread/73064/#post379741#post379741
Hi, I have a Nokia N78 and have been having great difficulty accessing ny Orange / Wanadoo Livebox (WIFI router). I get a reply asking for pre-shared key for WLAN. I've typed in the WEP code for my router which does not work. Under settings, connections, destinations, add new access point, I have configured a connection for wireless WLAN, public, infrastructure, WEP with WEP key added but no success. Any ideas?
Hi!
I wonder, is there any way I can install a program or something to speed up the frame rate from 15 fps to 30 fps or more when recording video with the N78?
Thankyou!
I�ve not seen alot of answers in this thread yet.. hmm... ? 😉
Steve1811 wrote:Hi, I have a Nokia N78 and have been having great difficulty accessing ny Orange / Wanadoo Livebox (WIFI router). I get a reply asking for pre-shared key for WLAN. I've typed in the WEP code for my router which does not work. Under settings, connections, destinations, add new access point, I have configured a connection for wireless WLAN, public, infrastructure, WEP with WEP key added but no success. Any ideas?
Hmm I'm not familiar with the Livebox, so hopefully someone else can answer. With WEP keys you do need to make sure it is the right format / spec too. You might try adding the WiFi via the WLAN scanner on the Idle screen - tends to be a bit easy for secure hot spots.
Danlo wrote:Hi!I wonder, is there any way I can install a program or something to speed up the frame rate from 15 fps to 30 fps or more when recording video with the N78?
Thankyou!
I don't know of anything and I suspect it is a hardware limitation.
I have some Chinese and Japanese songs uploaded to my n78.
Is there any way to make n78 display Chinese and Japanese characters as well?
Thanks.
Does the nokia n78 support 12gb and 16gb memory cards?
Malcolm
I am pretty sure it only supports up to 8GB... from all the forum I read unless the new firmware actually allows you to put 12GB or 16GB memory card. (Is there a 12GB memory card?? Never seen one on sale)
Is FM transmitter available in India? I bought N78 a month back but can't seem to find it.
Which one is the latest Sportstracker version for N78?
is this forum still alive?
Can someone tell me about sportstracker?
vaibhavkumar85 wrote:Which one is the latest Sportstracker version for N78?
I downloaded the version Nokia Sports Tracker for S60 v3.2 and it works fine on my n78.
The n78 is also mentioned in the supported phone list there.
How can I embed sportstracker on facebook? Please help..
Process is simple. Go on the site, click on get widget, personalize a name an colour for urself and give your sportstracker user name, once u click on next it will lead you to ur facebook page. After you login you will see it automatically embedded on your facebook account. all your facebook friends can then view watevr trails and media you'll record in your sportstarcker account.
Rafe wrote:If you have any questions about the Nokia N78 please let me know and I (or someone else) will do our best to get them answered.Rafe
Links of Interest:
N78 Gallery
N78 Preview
Hi! i just bought a China made Nokia N78 but when i transferred videos from my PC to my phone it only ran up to 36 minutes of the whole playing time. I tried different videos (avi, 3gpp etc) and converted them to different types of video converters and played it on my phone but still got the same result. Can you help me why is this so? I'm getting frustrated...Thanks..:con?
Currently my N78 is using the latest firmware v12.046. Recently I changed the product code to make use of different language set but to my dismay, I found the newest NSU doesn't allows me to reflash my phone since it's already running the latest version.
Did anyone of you face this problem? Is there anyway to trick NSU to reflash my N78 again?
Please advise!
Every Nokia I have owned or played with has a simple standby clock screensaver. The N78 seems to be missing this feature. Does anyone know if there is some kind of trick to get it to show up?
I have tried cclock and largetime, but neither app works when the keypack lock is on. I want to be able to glance at my phone to check the time, date, or see if I have missed calls or texts. Even the new E71 has this feature. Any ideas?
mo98 wrote:I have tried cclock and largetime, but neither app works when the keypack lock is on. I want to be able to glance at my phone to check the time, date, or see if I have missed calls or texts. Even the new E71 has this feature. Any ideas?
if you have missed calls or texts, the "breathe" feature will glow twice instead of the slow single one.
i haven't figured out the clock screensaver, mostly because i like the black - i assume it saves battery. if i need the time, i just press a button without unlocking it and it lights up for a second.
I got an email from Nokia care, and they confirmed that there is no standby clock in the software. You can find apps to do the same thing, but the clock will not display once the keypad locks. I have my keypad on autolock after 1 min, so apps like largetime and cclock just don't do it for me.
hi...searched hi and low for a quick fix to my problem...the backlight turns off after 3 seconds it only stays on for a long time when using the maps app...anyone that can help me pls do! Its very frustrating to double tap on the buttons to see what u doing on the screen and yes the backlight settings is set to the max in the settings menu
This usually happens when the phone is set to autolock (with a code). Turn that off and the light timeout problems should disappear..
Some reviews say it has tv out, others say it does not. Can someone say for sure if the N78 has this feature?
Also a somewhat related question, how well do emulators(nes, super nes) play on this phone?
I just posted "Lost automatic search on links in SMS - how to restore it?" on another thread, not allowed to post the url here, anyway any suggestions appreciated!
I heard that nokia has stopped producing n78. Can someone confirm this?
Also, I heard that n78 freezes a lot. Also that it has problems recognizing the memory stick & that it freezes while recognizing the audio files stored on the mem card.
Also have read about various other problems with n78.
Can someone please tell me how valid these are and is it worth buying it. I currently have a SE G700.
I like to have a performance comparison.
Thanks in advance!!!
There's a new firmware revision for the N78 out Dec/Jan and becoming available bit by bit depending on network operator. Most of the feedback from early adopters seems good. Nokia has a lot of similar model with overlapping functionalities so no surprise of they drop some models.
I bought the N78 for some specific functions e.g. the WiFi and ability to convert it into a WiFi hotspot. Anything else is a bonus.
Hi all, I need to update my N78 to version 20 I found the product codes here in the forum - Thanks - but I don't know wich one contain the arabic language and wich one can I use to make the FOTA work?
How can I play .wmv file (windows media 8 coded) on My N78?
Thanx
hey, i just bought a new n78
and the problem em facing is wid the video is,
when i play it sumtymes the screen doesnt
show anythin as in the real player shows its logo
or the real player screen goes blank and u cud
only hear the audio but no video!!
I am facing the same problem about the video. got sound but unable to view video. can someone tell me what is going on?
