has anyone gotten a system error message on their n95s whenever the phone starts up? also spontaneous resets by the phone by itself?
my phone started doing it a few weeks ago. tried reseting and reinstalling software, still shows up
Karlo_N80ie wrote:has anyone gotten a system error message on their n95s whenever the phone starts up? also spontaneous resets by the phone by itself?my phone started doing it a few weeks ago. tried reseting and reinstalling software, still shows up
You can do the format using this simple key combination *#7370# and the phone will prompt you to enter the phone lock code which is 12345 by default
BACKUP as this will delete all files from phone but may fix your issue
Ronaldo-9 wrote:You can do the format using this simple key combination *#7370# and the phone will prompt you to enter the phone lock code which is 12345 by defaultBACKUP as this will delete all files from phone but may fix your issue
Do as Ronaldo-9 says but DO NOT restore Settings from your Backup. Personally I would reload everything manually as Backups do cause problems, particularly after firmware upgrades or debranding.
Yup i only restore contacts i manually change settings
before formatting the phone, remove any Psiloc software you have and check that it also removed the DRM garbage that it also installed. I found this really screwed up my bootup times and all sorts of things. 2nd thing that was causing a bootup error was the bluetooth drivers for the dell keyboard adjoi installed to internal mem.
