I have recently upgraded my N95 to the lastest firmware version(21?) Since the upgrade every time I switch my PC on PC Suiter does not see phone either via Bluetooth or by USB. I have to go to the Nokia site and download the software again. The program then repairs PC suite and everything works...until I turn off PC. I have uninstalled PC suite and installed it fresh but am still having the same problem. Anybody had the same problem? Any suggestions?
Problem with Nokia PC Suite
nokia have removed it from their "approved" or "likely to work" list.
My suggestion is if you are running it on vista try to run it in XPSP2 compatibility mode.
The other possibility is that you have some firewall or anti-virus software which might interfere with the PC suite's ability to send/receive from the phone.
beyond that .. sorry .. Good Luck!😊
If you are using Nokia PC Suite 6.86 you could try downloading Nokia Nseries PC Suite from here:-
http://www.nseries.com/index.html#l=support,downloads,nseriespcsuite,download
Good luck!
