Problems after software update
0 replies · 1,492 views · Started 07 June 2008
I updated the software on my N70 and since then the phone says the memory card is unaccessible and every time I turn it off, when I switch it back on the orange home screen has come back. If I go into the menu and turn it off the phone restarts itself and is then fine. Can I revert the update? or do something to fix it? I've tried a second memory card but that doesn't work either
thanks
