Is there a way to downgrade the firmware?
5 replies · 10,086 views · Started 08 June 2008
Hey guys I have the N95 8GB NAM and I updated the firmware, but apparently the new firmware is VERY buggy so I decided if there is a way for me to go back to the original firmware it came with? Any help will be appreciated and I apologize ahead of time if this is a repost. I tried using the search, but came up with no answer.. Thanks!
simple answer is no you cannot downgrade.
only people who can are Nokia, they and few business have flashing kits worth thounds of pounds which can allow downgrade.
chungdae wrote:Hey guys I have the N95 8GB NAM and I updated the firmware, but apparently the new firmware is VERY buggy so I decided if there is a way for me to go back to the original firmware it came with? Any help will be appreciated and I apologize ahead of time if this is a repost. I tried using the search, but came up with no answer.. Thanks!
There may be some phone repair shops and internet sites who can do this, but there is a very high chance of permanently bricking the handset attempting a downgrade.
I would recommend you wait for the next FW release - if the current one is as buggy as you say, then surely you won't have to wait long for a new release...
honestly i would hard reset your phone. in another forum we are discussing the new n95-4 firmware v20 and its not getting many buggy reports, so i think you might have an isolated problem perhaps. hard reset and see if it fixes it.
