hi i hope someone can help me i have had my n-95 for some months now and no problems untill today i went to use my calculator and a message comes up on screen : calculator feature not supported any ideas what might have caused this and how can i get around it . n-95 on 3 network current firmware installed.
thanks in advance :con?
calculator help
Personally I don't use the N95's calculator as I prefer the free Calcium one from here:-
However you could try entering *#7370# from the front screen after first backing up everything on your phone as this code will return it to it's factory state.
Alternatively you could reinstall your firmware using the Nokia Updater.
Good luck!
every phone i buy gets calcium right away, so i dont know. its free and way better than that horrible nokia version, so just install that and be done with it. i dont know what your problem would be though...sorry.
ill give calcium a try thanks for your help
martyn:icon14:
