I have an N95 8GB. I have installed many themes over the past year, but cannot find an option to remove the unused themes from my phone. They even stayed on after the latest firmware update. Any suggestions?
Removing Themes
try removing ya memory card where you installed them onto.... lol
Well, that would be the easiest option.....but the N95 8GB does not have a memory card. It's 8GB internal memory.
Applications
App Manager
scroll to the theme and then select options then remove
Ronnie
I take it you have tried the application manager?
They don't show up in the Application Manager either...tried that already.
lol i was joking about removing card. what i was trying to say is that teh n95 8gb handles the 8gb as a seperate memory. so that if you do firmware install it doesnt touch the 8gb at all. just in the same way my n95 handles the external 8gb micro sd card.
So maybe your themes were saved to the 8gb memory. try deleting from there, or use data suit with pc to manually delete them all. good luck.
