Hi all, I had a bit of a brainwave the other day...
I have been wiring in a new stereo into my car... The rear of the head unit has 2 Phono 'Aux in' connectors (Meant for a CD changer) but using the N95's TV out lead, I can hook the left and right audio to the head unit..
Excellent, now I can throw the CD changer away and listen to my many hours of music on the N95.
I then wondered about the microphone modification. The N95 has a mic input, but is not officially supported for some reason, and the only real place you'll find it is on the official handsfree music controller (Not ideal for in-car use)
I searched eBay for the microphone used in their old handsfree kits (the wired ones) and found one for �5.50 inc postage, brand new. I don't know the part number but look for 'nokia visor microphone'
It arrived this morning and I was a little wary as to whether it would need a 9v power source to work (the N95 does not supply one).
I chopped the 2.5mm connector off the mic, and held the 2 wires onto the yellow lead of the TV cable, then plugged it into the N95 and when asked I selected 'Headset'
I called home, and everything worked fine, clear sound!
So, now I have a quality audio system in my car, which will be removed every time I leave the vehicle, making it safe from thieves, and also, I have a decent quality handsfree kit
I was also thinking about dismantling the nokia MP3 controls/microphone unit, and making a steering wheel control button unit, for the N95's stop/play/pause/ffwd etc etc. That can't be too hard to do.
I hope this thread will be useful to other people here, but if not, or it's been covered elsewhere (couldn't find it) feel free to delete.
When I've made a pretty phono lead to connect it all up I'll post pics
Thanks all,
Andy
