Repeated Cloned Files in my Gallery
5 replies · 3,112 views · Started 12 June 2008
I'm have a strange problem in my N95 8GB, I keep on getting repeated displays for the same file in the gallery :con?. When I erase that file another file gets repeated and so on.... The actual number of files in my galley not more than 50 files. But what is listed is 276 files. This means I have a file cloned 225 times. Is there a way I can stop this fro happening? Also I sometimes get a message of Disk Error Can't read. Does that mean that I'm having a problem with the internal storage? I press OK and nothing happens. But What I have noticed is that sometimes my Display Theme changes to the Default theme automatically. Hope that someone shared my problem before and has a solution for it.
baher4ever wrote:I'm have a strange problem in my N95 8GB, I keep on getting repeated displays for the same file in the gallery :con?. When I erase that file another file gets repeated and so on.... The actual number of files in my galley not more than 50 files. But what is listed is 276 files. This means I have a file cloned 225 times. Is there a way I can stop this fro happening? Also I sometimes get a message of Disk Error Can't read. Does that mean that I'm having a problem with the internal storage? I press OK and nothing happens. But What I have noticed is that sometimes my Display Theme changes to the Default theme automatically. Hope that someone shared my problem before and has a solution for it.
If all else fails, try formatting the memory - not an ideal option I admit...
With an N95-1 I would have recommended removing the memory card, then launching the Gallery to see if all the thumbnails disappear, then re-insert the memory card.
As far as I know, you cannot simulate this on an N95-8Gb?
dez_borders wrote:If all else fails, try formatting the memory - not an ideal option I admit...
I will try the Clean Boot option (long pressingon the Pen key) while restartingthe phone and check again. Formating the phone will be a cruel solution to solve that problem. I will do my best to avoid this.
This is because the gallery creates thumbnails of the images in the gallery in several sizes for display purposes in the various views of the gallery etc
dez_borders wrote:With an N95-1 I would have recommended removing the memory card, then launching the Gallery to see if all the thumbnails disappear, then re-insert the memory card.
Sure, just connect the N95 8GB to a computer in Data Transfer mode 😉
