E61 I randomly saving texts to Drafts instead of sending them!
2 replies · 4,924 views · Started 12 June 2008
As you can imagine, this is very annoying as I assume someone has been sent a message only to later find out the phone has not sent it but has saved if as a Draft!
I now have to manually check messages have actually sent by going to the Sent folder. 😞
De branded (Voda) E61i on PAYG O2 in the UK.
Any help appreciated.
P.S. In the settings the phone is set to reply to texts via the same call centre it receives them. Read somewhere that if not set to this then it can cause problems.....not a cure for me though. 😞
bump bump
I am having the exact same issue on my E71.
It's really aggravating!!
ps. i have my settings set to reply via same message center as well.
whats the Outbox for if its sending it to Drafts! ugh
