Hi All
In messaging, when I click to 'Write short message' my Communicator (with 4.13 software) replies with Note - not found.
It's kinda like an application is missing.
Any Ideas?
Many TIA
John
Hi All
Any Ideas?
Many TIA
John
Umm... I had the same problem once and I've fixed it with a full restore...
If you don't have a full backup of your 9210 I don't know... maybe you are in trouble... ![]()
Well... that's my opinion of course
Coolmatter
Try and view the settings for SMS, Shift+Ctrl+T when in messaging. It will probably sort it out.
I have the same problem.
Hear this The guys of Nokia Service Point formated all my device,and reinstalled the 4.13, but the problem goes on...And they don�t know why...
Thanks to all for replying so far...
Coolmatter Saddly, the only backup I have (since all the applications changed with the 4.13 firmware) is one I did when I first got the 9210 back from Communicaid. ![]()
LindaF I tried deleting the mail account and setting up a new one, but the problem still persists ![]()
ManoWar Looks like it's you and me then!
I had the same prob see thread
clean install dated 28 02 2002
the only solution I found was to take back to nok sav and upgrade to 4.13
I jusqt got the nok back and am trying to anylise to find out which files have the sms and fax config in them
It would appear from a quick glance that they are in the Z drive
if you have 4.13 I can send you the backup I did to mem card in the sav centre
so it should be clean its in french but if you reinstall this back up and then reinstall ontop the english all data files for both mem and comunicator that should work (it worked the other way round for my 9110 a couple of years ago from english to french)
think about it see what other fourum members think and let me know
Chris
PS
I think its time for a third party to write a backup / restore prog for the 9210 that works 100 per cent
just load sms.sis or the All_memory_data.sis , this worked for me, just download the latest ver from the nokia forum site & after loading it ,restart the phone 7 it should work.
ciao
gaurav
Where in the world have you found the sms.sis gauravonline?!?
When I had the same problem... (Not found for sms) I went to a Nokia Support Center and they reinstalled the 4.13 and when I got home the first thing I did was to take a full backup!
So... Anonymous if you want I can send you my clean backup to test it and see if it works... otherwise you SHOULD go to Nokia...
That's all!
Coolmatter
OK...
I've finally got it going. This is how...
Remove Battery (to close everything).
Connect to PC.
Copy key .sis files to D.
Run PC communicator App (the one it installs as an Icon on the desktop - not PC Suite - and format C (could not get CTL+Shift+F to work).
Re-install PCmail_V413.sis and fax_V413.sis first (for some reason not in all_Nokia_9210_data_V413.sis).
install all_Nokia_9210_data_V413.sys to D
install allmemcard.sis to D
Voila - all working again. ![]()
Obviously formating C cleared of some 3.62 remnants.
Many thanks again to all that replied.
Best wishes
John Walker (who did at one time have a password but now can't get it to work!)
