My one of the DPAD keys in my 1 year+ old N95 is acting up. I have to hit one key multiple times for it to register. I looked at the service manual and found the part I need is the A3 dome sheet (part I103). Anyone knows where I can order this part? I am pretty good at assembling stuff and have already opened up my phone to check for dirt etc. But contacts are sealed so I think I need to replace the whole part.
TIA for your help!
Just FYI, the A3 dome sheet is the one underneath the D-PAD, on the slider part of the phone. Every time you press a button on the D-PAD, it activates one of the "domes" on the dome sheet. TIA for your help!
Are you sure it's not the keypad itself that is acting up? It's easier to change than the "domes".
I am pretty sure it's not the keypad. I can feel the action on the one dome. I know that it attaches with a long ribbon cable and you may need to replace the slider module itself. =( According to the service manul, it actually much easier to change the dome on the numeric key pad that the dpad. go figure...
