What is fixed dialling? How do i use it?
9 replies · 3,453 views · Started 06 February 2003
Apart from the question in the topic name, I also wanted to know, why my call costs wont work? I've set the units to 2.5 as i am charged Rs 2.5 per min for incoming and outgoing. But after making a call, it still shows 0 Rs.
Thanks,
CJ
[quote="cj99"]Hi,
Thanks,
CJ[/quote]
AFAIK, the availability of call costs calculating is set by your service provider.
[quote="cj99"]...wanted to know, why my call costs wont work?...[/quote]
The network must also support that for it to work.
Fixed dialling?? No idea. Whats that? 😃
I think it means that you can only dial and receive calls from a fixed group of numbers � don�t quote me though!
[quote="BIGBANG"]I think it means that you can only dial and receive calls from a fixed group of numbers � don�t quote me though![/quote]
I got it figured. Like the earlier post, fixed dialling is a setting available under the sim menu option. It allows you to specify numbers from your contact list and olny these numbers will be allowed outgoing calls. There is no restriction on incoming calls.
I wish someone made an app to measure call costs using the call duration data. Its just a simple multiplication after all! I'm sure many people will benefit from it.
CJ
[quote="cj99"]
CJ[/quote]
Its availble on all 7650's! Itsd built in sorta! And all SIM cards do support it, way to do it is Menu>extras>calculater ... enter minutes u were on phone for then times buy call charge! Hehehe 😃 Fancied bein sarcy after a week ban
[quote="cj99"]Fixed Dialing
CJ[/quote]
Just use the Speed Dialing of your 7650. It's basically the same.
